Miele SpüMa G646 SC
Reparaturtipps und Ersatzteile zum Fehler: Start / Ende blinkt
Serverzeit: 24 11 2026  14:19:02      TV   VCR Aufnahme   TFT   CRT-Monitor   Netzteile   LED-FAQ   Oszilloskop-Schirmbilder
SpüMa Miele G646 SC --- Start / Ende blinkt
Suche nach Miele G646 Start / Ende blinkt
BID = 782335
evgenka
Defekt : Start / Ende blinkt
Gerätetyp : G646 SC
I am sorry I am writing here in English, but my German is not good (I can read your replies in German using Google translate, though)
I have the following problem with my dishwasher:
1. When I turn it on, even before setting a program and pushing "Start",it fills with water.
2. When I do start the program, it starts to pump the water, but also turns on the water heater (I opened the machine and saw the heater getting hot) but since there is no water going through the heater, the overheating relays jump and the heater stops working.
3. The machine then fills back with water and starts "working", but with no heating... After 2 hours it stops, with "Start" and "Ende" leds blinking and the machine is full with water.
I checked the failure memory as it described here in forums and it shows failure on 5 o'clock.
Could you please help me to identify the problem?
Thanks!
BID = 782389
shotty
Hello evgenka,
welcome to the forum.
If I understand this right, water runs into the machine without the program was launched?
greeting
shotty
BID = 782450
evgenka
Hi shotty,
yes, water starts running into machine when I press the "On" button, even if I don't choose any program (I put the dial on "stop").
It stops when the bottom of the machine is full.
BID = 782556
shotty
Hello evgenka,
that looks like a faulty electronics. Usually a male's fault. This sits at the bottom of the machine where you can sit the electrical components of the device.
Check times this connector, the mounting plate to be dismantled at the dishwasher. He sits on the right side, and connects the device with the water inlet hose. Pull the plug apart and see if he is scorched.
To check the electronics, they develop and expand from their plastic housing. Usually you can already see the faulty thyristor on the board.
And before you build the device apart, disconnect the dishwasher from the mains.
I hope the Google translator translates everything correctly.
greeting
shotty
BID = 783082
evgenka
Thanks shotty!
It really was faulty transistor on the board.
I replaced the transistor and everything works fine! I don't need to wash dishes again!
© x sparkkelsputz        Besucher : 194495049   Heute : 11612    Gestern : 16862    Online : 261        24.11.2026    14:19
