MIELE WaTro T410
Serverzeit: 21 11 2026  23:36:05      TV   VCR Aufnahme   TFT   CRT-Monitor   Netzteile   LED-FAQ   Oszilloskop-Schirmbilder
WaTro MIELE T410
BID = 417272
5 X
Geräteart : Waschtrockner
Hersteller : MIELE
Gerätetyp : T410
Hello,
My name is Daniel. I am French.
I do not speak or read German at all.
I am looking for help in English or French to repair a Miele Wash dryer T410 which does not heat anymore.
Thanks in advance
Bonjour,
Mon nom est Daniel, Je suis Francais.
Je ne parle pas allemand du tout.
Je recherche de l'aide en Francais ou Anglais pour reparer mon seche linge Miele T410 qui ne chauffe plus.
Merci d 'avance.
Daniel
BID = 417339
Gilb
Zur Homepage von Gilb
Hello Daniel,
sorry, my english and frech are very bad.
I try to explain it with photos:
Dismount the bolts (x) and renew the right "Thermostat".
Best wishes
the Gilb
BID = 417356
5 X
Gilb hat am 26 Mär 2007 14:23 geschrieben :
Hello Daniel,
Best wishes
the Gilb
Gilb,
Thank you very much, I do appreciate the help
I opened as shown on the picture (without the picture I would not have found the center screws for sure) and found that both "thermostat" were very very dirty with the material that normally come out of the wash dryer. I cleaned them, and now it works.
What happened is that the evacuation pipe below the engine was a bit disconnected, and so the dryer has been swallowing some of the material rejected for a while, to the point where the "thermostat" was completely covered by dust, and I suspect it it the mechanical one that has been stucked by dust.
You know what ? European support works, thank you again believe in Europe
Daniel
BID = 417363
Gilb
Hello Daniel,
many thanks for your response.
Yes, the pipes must be correctly connected.
I'm happy, that I was helped you.
(sorry for my english, hope that you understand my minds)
For a friendly europe
the Gilb
All your questions are cleared?
BID = 417376
5 X
Yes Gilb, everything is solved now.
I don't know how to close the thread. Can you do it for me?
Daniel
© x sparkkelsputz        Besucher : 194444411   Heute : 20192    Gestern : 29111    Online : 395        21.11.2026    23:36
6 Besucher in den letzten 60 Sekunden        alle 10,00 Sekunden ein neuer Besucher ---- logout ----viewtopic ---- logout ----
