miele Waschmaschine  w 452
Reparaturtipps zum Fehler: Kein Satz von Wasser
Serverzeit: 29 12 2024  10:20:33      TV   VCR Aufnahme   TFT   CRT-Monitor   Netzteile   LED-FAQ   Osziloskop-Schirmbilder
Waschmaschine miele w 452 --- Kein Satz von Wasser
Suche nach Waschmaschine miele
BID = 710465
tiuris
can anyone tell how to make a test?
thanks
BID = 710585
usuallyusefulforyou
which kind of test do you mean?
W.G.
BID = 710686
tiuris
usuallyusefulforyou hat am 27 Aug 2010 19:23 geschrieben :
W.G.
"Quick test" and where you can see errors
BID = 710747
driver_2
Hello,
if "Zulauf prüfen" and "Ablauf prüfen" are blinkting similar, the Safety-Switch on the Floor requested Water on the Floor inside the machine.
If you lean the machine a large angle on the side and there is coming Water from the Metal floor pan running outside, you must check the rubber maid connections inside.
If there is coming no water, check if the piece of Styropor which swims on water and touches the switch is proper in line and not destroyed or damaged or worn up.
If this is also not the cause for the blinking lights, check the wire to the Powerboard EL-140/150 the wire musn't broken, in normal use, the circuit is closed ! If you connect the contacts at the Powerboard and the lights shut off, the wire is broken or the switch damaged.
BID = 710761
tiuris
Thanks driver_2 but I already checked all ok
vchem More could be wrong?
BID = 710936
driver_2
Could you scan the circuit diagram in a proper quality, which lays normally inside each machine ? Or could you tell us the number of it ? Starting with TI11-???????
BID = 710940
tiuris
driver_2 hat am 29 Aug 2010 15:41 geschrieben :
its no longer there
BID = 710942
driver_2
Könnte bitt einer der Kollegen die Onlineversion des Planes
Baureihe W4xx Novo3-MidiS/Plus HyIVB1 online stellen, oder mir zusenden ? Habe keinen Bettscanner...
Plannummern 05349640
Plannummern 05349650
Plannummern 05349660
für alle drei Blätter.
Danke
BID = 710954
tiuris
driver_2 hat am 29 Aug 2010 16:15 geschrieben :
What are you going to say?
BID = 711067
Gilb
Zur Homepage von Gilb
Hi, driver_2,
my english is very bad, thank you for help.
here are the circuit-plans to the Miele W 452 S:    Inhalte ausgeblendet durch Gilb
   Forenregeln
[ Diese Nachricht wurde geändert von: Gilb am  1 Sep 2010  7:55 ]
BID = 711144
driver_2
If it is written in German, it is not for you.
Copy and save all three files, these are the original Plans to your Washing Machine.
File #3 to download: Make a shortbridge from 1/6 to 1/5 as optional signed on Powerboard EL150 called 1N1. If both LED's are not stopping blinking, there is a deeper electronic damage, which I cannont clear from here.
BID = 711390
tiuris
all ok
thanks for the scheme Gilb
BID = 711400
driver_2
tiuris hat am 31 Aug 2010 16:53 geschrieben :
all ok
Can I interpret this, that the machine is working now correct ?
If it is so, the damage must be in the wiring between 1N1 and the safetyswitch on the floor. Have a look, or let it be, if the room the machine works has a expiration on the basement.
If you live in a upper floor of a foreign house, repair the safetysystem, if the machine looses water and this runs down through walls and floors, the costs of this damage are thousands of €€€€.
[ Diese Nachricht wurde geändert von: driver_2 am 31 Aug 2010 18:06 ]
BID = 711402
tiuris
all ok
BID = 711403
tiuris
been washed twice
gerechnet auf die letzten 30 Tage haben wir 22 Beiträge im Durchschnitt pro Tag       heute wurden bisher 5 Beiträge verfasst
© x sparkkelsputz        Besucher : 182618222   Heute : 2119    Gestern : 8013    Online : 198        29.12.2024    10:20
