Miele Waschmaschine  W719
Reparaturtipps und Ersatzteile zum Fehler: Timer not working
Serverzeit: 26 3 2026  00:26:39      TV   VCR Aufnahme   TFT   CRT-Monitor   Netzteile   LED-FAQ   Oszilloskop-Schirmbilder
Waschmaschine Miele W719 --- Timer not working
Suche nach W719 Waschmaschine Miele W719
BID = 1128422
milivoj
Defekt : Timer not working
Gerätetyp : W719
S - Nummer : see attachment
FD - Nummer : 00/2240890
Greetings to all members. This is my first post here. I am an electrician by profession. I tried to repair the washing machine for my wife's father, and the only valuable help for Miele washing machines is on this forum.
My apologize for the post in English, I don't speak German
The machine didn't have both directions of rotation, only one. I took the programmer apart to clean the contacts and the gears fell out. Does anyone know where the spring marked in red goes and does anyone have a picture of how the gear phases fit together?
By logical observation, I tried to put it together, I started the machine, but I don't have a timer to move to the next operation. When the pressure switch or thermostat gives the condition to start the motor to move to the next step, then it works. But when the machine needs to make a certain number of revolutions and move on to the next step, it doesn't, it always stands on the same position and spins in both directions.
For this reason, I think I made a mistake somewhere in the assembly. Or maybe the timer is from the motor electronic board?
Any idea would help me.
PDF anzeigen
PDF anzeigen
PDF anzeigen
BID = 1128429
driver_2
Nobody of us, expect me perhaps long years ago, opened a Timer to clean contacts, but my attempts were always completed with bad result.
You need:
1900200Ersetzt ↓ Programmschaltwerk CR 8001 220/240V
1900201Ersetzt ↓ Programmschaltwerk CR 8001 220/240V
1900202Ersetzt ↓ Programmschaltwerk CR 8001J 220/240V
2300810Ersetzt ↓ Programmschaltwerk CR 8001K 220/240V
2300811Ersetzt ↓ Programmschaltwerk CR 8001L 220/240V
2300812Ausgelaufen Programmschaltwerk CR 8001N 220/240V
https://www.youtube.com/watch?v=e0FlvvxxSEQ
Tell me your complete Data of the timer, there is a stamp on the side, perhaps i have one at home still here.
BID = 1128446
milivoj
Motor 220-240V 50Hz
Typ 88718001 L
T.-Nr.2300811
Thanks for the video. I will compare it with the video of how I assembled the gears.
BID = 1128448
driver_2
I have two.
The left one is for a later Version, the right one for yours.
BID = 1128449
driver_2
If you want the right one, write me a PN, we'll talk about the postal and the money.
BID = 1128654
driver_2
Have you taken a step forward in your efforts?
gerechnet auf die letzten 30 Tage haben wir 10 Beiträge im Durchschnitt pro Tag       heute wurden bisher 0 Beiträge verfasst
© x sparkkelsputz        Besucher : 190627872   Heute : 558    Gestern : 24698    Online : 286        26.3.2026    0:26
