Philips TV RGB?
Serverzeit: 16 11 2026  18:10:57      TV   VCR Aufnahme   TFT   CRT-Monitor   Netzteile   LED-FAQ   Oszilloskop-Schirmbilder
TV Philips RGB?
BID = 44948
fluddyflea
Geräteart : Fernsehgerät
Hersteller : Philips
Gerätetyp : RGB?
Chassis : 28pt4521/1
Hello! Sorry, I'm not very good with german so I hope it's ok that i stick with english :)
Anyway I have a Philips 28PT4521/13 (2 scart connectors) that I bought second hand a couple of weeks ago. I use it mainly for playing with my Nintendo Gamecube. The weird thing is... there is no picture when I use my RGB-cable. The cable works perfectly with both my Panasonic TV (about 5 yrs old) and a really old (8-10 years perhaps) Supertech TV.
I'm not very good with TV's but I thought all half new TV's would support RGB through scart. I don't know how old this TV is though, maybe you could help me with that too . Maybe the RGB-terminal (or whatever it's called) is broken? Or this TV shouldnt support RGB at all? In that case, can I go to a TV guy and he can put an RGB terminal in it? How expensive would that be (roughly?)
the AV button switches through three "modes": EXT1, EXT2 and EXT2 Y/C. When RGB cable is in EXT1 I get only sound (i get a picture for about 1/10th of a second), In EXT2 I get a _really_ bright composite-looking picture (useless) and when using EXT2 Y/C i get the same bright picture but much dizzier. With my normal composite scart cable I get a fine picture in both of the TV's scart connectors, but i dont want composite :(
Thanks very much for any help you can give, and once again, sorry for writing in English.
// Mark Slight from sweden =)
BID = 45185
themarsantho
Dear Mark,
this TV must support RGB on EXT1.
But conform the SCART Standard there must be a switching voltage on pin 16 of the scart connector. (About 2,5V)
So pls. check if you use a full scart cable.
Maybe you can check it with a DVD player because every DVD player has RGB output.
Maybe the gamecube does not support the RGB Status on pin 16?
Good Luck,
theo.
    theijnen äht plex.nl (automatisch editiert wegen spamgefahr)
© x sparkkelsputz        Besucher : 194315000   Heute : 9779    Gestern : 12485    Online : 734        16.11.2026    18:10
