bosch SpüMa DAY & NIGHT Reparaturtipps und Ersatzteile zum Fehler: Im Unterforum Geschirrspüler - Beschreibung: Tipps für Reparaturen an Geschirrspülern, Spülmaschinen, Spülautomaten
BID = 481872
johannes.mulder Gerade angekommen
Beiträge: 2 Wohnort: Best, Nederland
Hersteller : bosch
Gerätetyp : DAY & NIGHT
S - Nummer : S6M22B
sorry at first: my german language is bad,
my english much better. But I can read german text.
I have a Bosch S6M22B dishwasher.
Quite old, but still working, until today.
Water is coming in, but it does not continue after that.
water stays cold.
I expect spooling at this point as well, but nothing happens.
When I turn the clock a little further by hand, it will
start spooling, but it stops again little later.
The spooling-only program shows the same behavior (I guess
this is a non-heating program, but I am not sure)
Pumping works well.
I checked the heating element, is not broken (low resistance)
I see a temperature switch (clixon-like) front right bottom, mounted to the heating element, no voltage across contacts.
So I conclude this does not prevent working.
I see 2 little elements, near this temp.switch, looks like temp.switch as well, mounted to the bottom on a copper rod.
Also no voltage across contacts.
Same conclusion
This machine has a start-timer, with some electronics, to delay
operation. Can this prevent proper working like described?
Any help would be welcome.
Johannes
BID = 487342
While no answer received, I did it the hard way: found out the schematic and clock program by myself (took a while :cry:).
It appeared that the levelswitch switched off the waterinlet correctly, but (the other side of the switch) failed to advance the clock, because of a weared-out contact.
Its wotking fine now.
For any other seeking for a solution, I leave my info here as well, as an excel sheet (not 100% complete, but should be sufficient to help solving most problems)
Johannes
BID = 487343
BID = 487353
prinz. Moderator
hello
this number is not correct - S6M22B
give the number to find open the door.
Lasered or adhesive label.
Yours truly
Nur für nicht Mutige
1.Freischalten
4.Erden und kurzschließen
Liste 1 BOSCH Liste 2 BOSCH |
gerechnet auf die letzten 30 Tage haben wir 8 Beiträge im Durchschnitt pro Tag heute wurden bisher 0 Beiträge verfasst © x sparkkelsputz Besucher : 194509424 Heute : 3363 Gestern : 22653 Online : 481 25.11.2026 2:13 23 Besucher in den letzten 60 Sekunden alle 2,61 Sekunden ein neuer Besucher ---- logout ----viewtopic ---- logout ----
0,0931928157806
