AT90S2313 - Watchdog
Serverzeit: 25 11 2026  04:31:14      TV   VCR Aufnahme   TFT   CRT-Monitor   Netzteile   LED-FAQ   Oszilloskop-Schirmbilder
BID = 375163
olfi13
Hi!
Ich bekomme den Watchdog nicht aktiviert.
; Hier ein paar Bytes die gesendet werden, mit Terminal zu sehen
wdr
ldi temp0, 0b00001101
out WDTCR, temp0
loop:
rjmp loop
Nach Reset werden die Bytes am Terminal angezeigt, da ich den Befehl wdr nicht mehr verwende sollte der µC immer wieder neu starten. macht er aber nicht.
Hat jemand eine Idee?
Gruß, olfi
Gruß, olfi
BID = 375239
DonComi
Hallo Olfi13,
hast du denn das Fusebit ensprechend programmiert, um den Watchdog zu aktivieren?
BID = 375273
.DSEG
Dog_Food: .byte 1 ;A place to store dog food
.CSEG
.equ Dog_Chow = 251 ;How many mS between feedings.
Init_Watchdog:
ldi TEMP,$0F ;000XXXXX Reserved
;XXX0XXXX Watchdog turnoff enable
;XXXX1XXX Watchdog enable bit 1=enable
;XXXXX000 (8) Watchdog timeout, 16mS
;XXXXX001 (9) Watchdog timeout. 32mS
;XXXXX010 (A) Watchdog timeout. 64mS
;XXXXX011 (B) Watchdog timeout. 128mS
;XXXXX100 (C) Watchdog timeout, 256mS
;XXXXX101 (D) Watchdog timeout, 512mS
;XXXXX110 (E) Watchdog timeout,1024mS
;XXXXX111 (F) Watchdog timeout,2048mS
out WDTCR,TEMP ;
;Initial states for watchdog timer
ldi TEMP,Dog_Chow ;Start a countdown for resetting the watchdog
sts Dog_Food,TEMP ;
BID = 375274
Timed_Smack:
;Whatever you need to satisfy the internal or external watchdog
;The internal watchdog can be set to 16,32,64,128,256,512,1024,or 2048mS
;This scheme for timed reset is limited to 255mS between resets, but it can
;be used with any of the timeouts above. Resetting a watchdog more frequently
;than is needed, is mostly harmless.
;Just make sure that the value you set the timer to at the end of INIT is
;GREATER than the value you assign for Dog_Chow in EQUATES.INC
;The code to set the watchdog to a particular interval is in INIT.ASM
push TEMP ;Some routines that need to use this,
;also need to use TEMP..
lds TEMP,Dog_Food ;How many milliseconds before reset is needed?
and TEMP,TEMP ;Is it zero?
brne Smack_Done ;Nope, just exit
ldi TEMP,Dog_Chow ;Reload the timer for the next occurence
sts Dog_Food,TEMP ;
wdr ;This code will reset the internal watchdog
ldi TEMP,$0D ;000XXXXX Reserved
out WDTCR,TEMP ;
Smack_Done:
pop TEMP ;
BID = 375276
Ach ja, beim 90S2313 gibt es nichts an den Fuses zu schrauben. Beim Tiny2313 ist das was anderes.
BID = 375278
DonComi
Soso,
Danke für die Info.
BID = 375687
oder so:
.include "2313DEF.INC"
.ORG 0
_Reset:
ldi yl,low(RAMEND)
out SPL,yl
sbiw yl,32
ldi zl,0x1f
out WDTCR,zl
ldi zl,0x17
out WDTCR,zl
;Start WatchDog
in zl,WDTCR
sbr zl,0x18
out WDTCR,zl
;Do
L0:
;Loop
rjmp L0
L1:
;Stop WatchDog
in zl,WDTCR
sbr zl,0x18
out WDTCR,zl
cbr zl,0x08
out WDTCR,zl
;Reset WatchDog
wdr
BID = 375850
JanG
Kleine Ergänzung zum Tiny2313:
Auch hier muss man keine Fuses setzten um den Watchdog zu aktivieren, man kann ihn genauso einschalten wie beim 90S2313. Allerdings hat der Tiny das WDTON-Fuse, womit der Watchdog dauerhaft aktiviert wird und per Software nicht mehr ausgeschaltet werden kann.
Beim Tiny kann man im Gegensatz zum 90S den Watchdog auch so einstellen, das er einen Interrupt und keinen Reset auslöst oder erst einen Interrupt und dann den Reset.
BID = 376333
olfi13
Danke jornbyte!
Zeit ist wieder einmal knapp geworden. Ich melde mich aber sicherlich bei Erfolg
Gruß, olfi
Gruß, olfi
© x sparkkelsputz        Besucher : 194512290   Heute : 6243    Gestern : 22653    Online : 419        25.11.2026    4:31
