humax Digital-RX IRCI-5400 Reparaturtipps und Ersatzteile zum Fehler: Im Unterforum Reparatur - Sat - Beschreibung: Receiver, Anlagen, Multischalter, D-Box Digita-Receiver, Festplattenreceiver usw.
Digital-RX humax IRCI-5400 |
BID = 170652
mnadeem Neu hier
Geräteart : Sat-Receiver digital
Hersteller : humax
Gerätetyp : IRCI-5400
Chassis : smps
Hi
1 --- I have a problem that the receiver is not going on , found that first the ZD3 30v is dead, replaced , but then found the resistance R2 180kohm is blown out replace , still having same problem , ? .. what is the voltage on pin no 3(V)of ic ILO380R ,,, also changed all kinds of capacitors in PSU also critical resistance 100ohm R21 ..the receiver is chaked with other supply is ok .
2 ---- i have other receiver also humax F1 vaci , can not update with com rs232 and also taking too much time to on saying no signal ,, no voltage 13/18 , but after a wile coming back but only 18v on h , what could it be .
thanks waiting for your reply and advise
BID = 170695
mnadeem Neu hier
Hi
My german is not too good ,but i can understand , if you write me something ..
So.. Can it be that TP1 is also dead or open , second one of my freinds said that i must also changed the cap C24 and C5 what is the value of ZD2
BID = 170779
Satfan123 Sat- und DBox-Spezialist
BID = 171051
mnadeem Neu hier
Hi dir
Thanks for info ,, but i have the manual , I also changed all capicitors , also cheked ZD2 , bring me nothing the resistance R4 68ohm is ok with D6 working properly , ?
R1 47kohm also ok
BID = 171182
try a new PSU
cost @ ebay 20-29€
BID = 173644
mnadeem Neu hier
HI
thanks any way
I have changed the capacitors no 9 and the haupt ic transistors 1lo380r and every thing ok , second ebay is high cost ,, i have found no artical that will bring upto 20 euro
gerechnet auf die letzten 30 Tage haben wir 7 Beiträge im Durchschnitt pro Tag heute wurden bisher 8 Beiträge verfasst © x sparkkelsputz Besucher : 194630548 Heute : 9076 Gestern : 19015 Online : 137 30.11.2026 19:51 7 Besucher in den letzten 60 Sekunden alle 8.57 Sekunden ein neuer Besucher ---- logout ----viewtopic ---- logout ----
0.028648853302
