nokia Digital-RX dbox1 dbox1
Serverzeit: 25 11 2026  23:25:07      TV   VCR Aufnahme   TFT   CRT-Monitor   Netzteile   LED-FAQ   Oszilloskop-Schirmbilder
Digital-RX nokia dbox1 dbox1
BID = 118176
rinko
Geräteart : Sat-Receiver digital
Hersteller : nokia dbox1
Gerätetyp : dbox1
noise from trafo LS 04
change : lm317 and ts07 and con.cs02 47uf 400v
still have the noise
box works fine only the noise from LS04
thanks rinko
BID = 118230
Satfan123
Sat- und DBox-Spezialist
change the ls04
you can buy at www.ekssat.de
BID = 118426
rinko
thanks satfan 123
I must replace the trafo LS04 not the lm IS04 correct?
i send order to ekssat
thanks greetings rinko
BID = 118442
Satfan123
replace LS04
BID = 124043
rinko
@ satfan 123
i have change trafo now box works great
no noise more
thanks satfan 123
greetings rinko
© x sparkkelsputz        Besucher : 194531731   Heute : 25728    Gestern : 22653    Online : 393        25.11.2026    23:25
