Imp. LED soll Schaltung auslösen Suche nach: led (32869) schaltung (31790) |
BID = 980426
damianator Gerade angekommen
Ein ISKRA MT173.
Und das spuckt er aus:
| Code : |
==> /?!<0D><0A>
<== /ISk5MT173-0263
==> <06>050<0D><0A>
<== -- STX --
<== 1-0:0.9.1*255(0221334)
<== 1-0:0.9.2*255(160122)
<== 0-0:C.1.0*255(47032259)
<== 1-0:0.0.0*255(00000100)
<== 1-0:0.0.1*255(00146767)
<== 1-0:0.1.0*255(73)
<== 1-0:0.2.0*255(V1.11)
<== 1-0:0.2.2*255(41)
<== 0-0:C.51.1*255(2)
<== 0-0:C.51.2*255(1100401080451)
<== 0-0:C.51.2*1(0100309153311)
<== 0-0:C.51.2*2(0000101000000)
<== 0-0:C.51.2*3(0000101000000)
<== 1-0:1.8.0*255(029984.5 kWh)
<== 1-0:1.8.1*255(021107.9 kWh)
<== 1-0:1.8.2*255(008876.6 kWh)
<== 0-0:F.F.0*255(00000000)
<== 1-0:1.8.0*01(029447.2 kWh)
<== 1-0:1.8.0*02(028908.4 kWh)
<== 1-0:1.8.0*03(028427.2 kWh)
<== 1-0:1.8.0*04(027955.9 kWh)
<== 1-0:1.8.0*05(027642.4 kWh)
<== 1-0:1.8.0*06(027400.6 kWh)
<== 1-0:1.8.0*07(027149.3 kWh)
<== 1-0:1.8.0*08(026824.1 kWh)
<== 1-0:1.8.0*09(026408.6 kWh)
<== 1-0:1.8.0*10(025994.9 kWh)
<== 1-0:1.8.0*11(025459.3 kWh)
<== 1-0:1.8.0*12(024880.3 kWh)
<== 1-0:1.8.0*13(024333.9 kWh)
<== 1-0:1.8.0*14(023702.9 kWh)
<== 1-0:1.8.0*15(023207.0 kWh)
<== 1-0:1.8.1*01(020711.4 kWh)
<== 1-0:1.8.1*02(020301.8 kWh)
<== 1-0:1.8.1*03(019944.0 kWh)
<== 1-0:1.8.1*04(019591.9 kWh)
<== 1-0:1.8.1*05(019363.1 kWh)
<== 1-0:1.8.1*06(019185.6 kWh)
<== 1-0:1.8.1*07(018998.6 kWh)
<== 1-0:1.8.1*08(018756.9 kWh)
<== 1-0:1.8.1*09(018469.9 kWh)
<== 1-0:1.8.1*10(018184.8 kWh)
<== 1-0:1.8.1*11(017806.2 kWh)
<== 1-0:1.8.1*12(017388.4 kWh)
<== 1-0:1.8.1*13(016996.7 kWh)
<== 1-0:1.8.1*14(016547.1 kWh)
<== 1-0:1.8.1*15(016204.9 kWh)
<== 1-0:1.8.2*01(008735.8 kWh)
<== 1-0:1.8.2*02(008606.6 kWh)
<== 1-0:1.8.2*03(008483.2 kWh)
<== 1-0:1.8.2*04(008363.9 kWh)
<== 1-0:1.8.2*05(008279.2 kWh)
<== 1-0:1.8.2*06(008215.0 kWh)
<== 1-0:1.8.2*07(008150.6 kWh)
<== 1-0:1.8.2*08(008067.1 kWh)
<== 1-0:1.8.2*09(007938.7 kWh)
<== 1-0:1.8.2*10(007810.0 kWh)
<== 1-0:1.8.2*11(007653.1 kWh)
<== 1-0:1.8.2*12(007491.8 kWh)
<== 1-0:1.8.2*13(007337.2 kWh)
<== 1-0:1.8.2*14(007155.7 kWh)
<== 1-0:1.8.2*15(007002.0 kWh)
<== -- ETX --
<== -- BCC --
damianator
Stammmitglied
Stammmitglied
- Threadstarter -
Info: Interessent
BID = 980429
Maik87 Schriftsteller
Beiträge: 861 Wohnort: Wesel / Niederrhein
Erschwerend kommt hinzu, dass du zwei Tarifregister hast. Du musst also wissen, für welches Register die rote LED gerade blinkt, die du zählen möchtest.
BID = 980430
Grimm Stammposter
Beiträge: 499 Wohnort: Bayern
Hallo Jungs,
habe da eine falschen Widerstand erwischt, deshalb hat der Transistor bei Dunkelheit nicht gesperrt.
Geht auch mit einem alten aufgesägten Transistor das LED zu „Überwachen“.
Der Schaltstrom ist aber sehr gering, unter, unter 1mA.
[ Diese Nachricht wurde geändert von: Grimm am 27 Jan 2016 18:00 ]
BID = 980442
| | Erschwerend kommt hinzu, dass du zwei Tarifregister hast. Du musst also wissen, für welches Register die rote LED gerade blinkt, die du zählen möchtest. |
Die LED zeigt die z.Z. aktuelle Last.Egal welcher Tarif gerade aktiv ist.
Bei der Softwarelösung müsste man 1.8.0*255 auslesen.
Das ist der gesamtstand beider Tarife.
Der Schaltstrom ist aber sehr gering, unter, unter 1mA. |
Hast du das auch mit einer roten LED getestet?
Eine rote LED ist von der Wellenlänge (700nm) und nicht grad optimal.
BID = 980447
Prinzipiell funktioniert das schon mit jedem Transistor! Fototransistoren sind aber etwas anders aufgebaut und der Bastellösung um den Faktor 100 mindestens überlegen.
Eine Funktionierende Lösung wäre es die Fotodiode BPW21 und einen 339 zu verwenden. Oder du verwendest einen BPY 62/IV ( https://www.reichelt.de/BPY-62-IV/3.....istor ) mit einem R von rund 10 bis 100K nach +US
Edit: sollte der Fototransistor noch zu unempfindlich sein kannst du mit einem zusätzlichem Transistor auch einen Darligtontransistor aus dem Fototransistor und dem Zusätzlichen machen. Wichtig der Transistor muss nur ein sauberes H oder L am GPIO bei aufleuchten der roten LED liefern.
[ Diese Nachricht wurde geändert von: der mit den kurzen Armen am 27 Jan 2016 19:44 ]
BID = 980480
Grimm Stammposter
| | Hast du das auch mit einer roten LED getestet? |
Ja das geht auch aber wie gesagt ist eben eine Bastellösung und wollte ich einfach mal testen.
Ein Richtiger Fototransistor ist vermutlich 100 X besser.
Fotodioden nicht so Lichtempfindlich als ein Fototransistor so meine Einschätzung.
| | Eine rote LED ist von der Wellenlänge (700nm) und nicht grad optimal. |
Ob die Wellenlänge 700nm vom roten Test LED ist, keine Ahnung.
