Canon DRU oder HP LBP-465 oder Laserjet 5L
Serverzeit: 03 11 2026  04:15:02      TV   VCR Aufnahme   TFT   CRT-Monitor   Netzteile   LED-FAQ   Oszilloskop-Schirmbilder
DRU Canon oder HP LBP-465 oder Laserjet 5L
Problem gelöst
BID = 120940
TR78
Geräteart : Drucker
Hersteller : Canon oder HP
Gerätetyp : LBP-465 oder Laserjet 5L
Kenntnis : Artverwander Beruf
I have the following problem with my old LBP-465: when cold (idling for a long time) the paper is correctly fed, but stops before entering the toner drum zone. It must be removed, the printer reset (power off/on), then proceed again up to 4 times. Then the printing terminates quite well.
I suspect the pre-heating delay (not hot enough -> failure stop). I checked resistance of the built-in temp sensor, which is 400K. If disconnected, the printer doesn't start. The resistance of heating element is 146 ohms. Also, the 1st attempt seems to launch more quickly than before, when everything was OK.
To proceed further I need the schematic, or your help.
Thanks
PS: the LBP-465 has the same engine as 460/660 and HP Laserjet 5L/6L
Leider kann ich nicht gut auf deutsch schreiben. Aber Sie kônnen mir auf deutsch antworten. Ich lebe in Frankreich.
BID = 121139
Canide
Hi TR78,
if you send me your email-address via pm I´ll send you the service-manual you are looking for.
Best regards
Canide
Viele Grüße
Canide
BID = 121196
TR78
Hi Canide,
thanks for your reply . I already found and downloaded the HP service manual (publication C3990-90991, May 97). But unfortunately there is no detailed, component-level schematic. If yours does have it, would you please send it to me.
Today I tried to replace the triac which controls the heater (Mitsubishi BCR8PM) by an BTA06.700B (just because I have this one under hand). There is a clear improvement: the printing now only requires 2 attempts (instead of 4). So I am wondering if there is a trigger problem on the triac. It would be much easier to investigate with a schematic than just blind-trying .
Anyway I send to you my e-mail.
Best regards,
TTR
BID = 121234
Canide
Hi TR78,
unfortunately I also own only the manual you just downloaded, so I think there´s no need to send it to you for a second time. I also don´t have the schematics for this printer, so I hope you can get rid of this strange error even without the detailed schematics of the board.
Best regards
Canide
BID = 121586
TR78
From time to time I also encounter the failure described by Thuja (paper stops while exiting, the toner is well fused on beginning of the page, but not on the remainder). But there is no control leds on the Canon.
Anyway, if I find a remedy, I'll let you know.
Best regards
BID = 127943
TR78
finally I found the problem. It is related to transient failure of the pass-through connector of thermistor (fig 6-15, service manual). This kind of connector is convenient for maintenance, but increases the probability of contact failure. If it appears again, I will replace the connector with soldered connections.
Best regards
© x sparkkelsputz        Besucher : 194102117   Heute : 11432    Gestern : 70074    Online : 484        3.11.2026    4:15
50 Besucher in den letzten 60 Sekunden        alle 1.20 Sekunden ein neuer Besucher ---- logout ----viewtopic ---- logout ----
