Sagem D-Box IDT 4410
Serverzeit: 25 11 2026  19:30:09      TV   VCR Aufnahme   TFT   CRT-Monitor   Netzteile   LED-FAQ   Oszilloskop-Schirmbilder
D-Box Sagem IDT 4410
BID = 38320
owehor
Geräteart : D-Box
Hersteller : Sagem
Gerätetyp : IDT 4410
Regarding my previous problem with a Sagem terrestrial-box:
I have to re-program the EEprom and have found a
8 pin IC on the motherboard: 24C64N
Problem:
It is a SMD-type!
My programmer is for "normal" sized IC.
Desolder it and solder small leads to every pin
and then fit into the programmer??
Or....?
I have to desolder the chip from my working IDT4410.
Then read it and resolder it back in place.
What if I accidently break off a pin or in some way manage to make it unfunctional?
Is it not possible to find the correct data to input somewhere here at electronicwerkstatt??
Is it possible to read via the RS232 port at the rearside of the box?? (What is the port for anyway?)..???
BID = 38339
Satfan123
Sat- und DBox-Spezialist
you can buy for the programmer a dil to SMD socket
BID = 38346
owehor
What is the RS232 connector at the back good for??
And can i find software to input to the EEprom here on internet??
BID = 38371
Satfan123
the rs 232 connector on the rearside is to load the software in a box without errors
the soft in the net i don´t know
© x sparkkelsputz        Besucher : 194527800   Heute : 21793    Gestern : 22653    Online : 287        25.11.2026    19:30
