technosat Digital-RX or Medion IR 7000 or mds 3160
Serverzeit: 16 11 2026  18:36:19      TV   VCR Aufnahme   TFT   CRT-Monitor   Netzteile   LED-FAQ   Oszilloskop-Schirmbilder
Digital-RX technosat or Medion IR 7000 or mds 3160
BID = 100797
mnadeem
Geräteart : Sat-Receiver digital
Hersteller : technosat or Medion
Gerätetyp : IR 7000 or mds 3160
Chassis : v0204032246
Hi
I need circuit diagram 13/18 v/h section are not working want to know if thia fehler is in power supply kit or in
please send
BID = 100803
mnadeem
hi
the receiver is in germany ccalled medion mds 3060
BID = 102466
mnadeem
HI
Dir sir i have asked you for circuit diagram , but no responce , If you have it please send or tell me where to find . The receiver is totaly dead , The power supply section is blow out and the componnent can not read what could be .
please help
I will be great full to you
Thanks in regards
SECOND
I have another receiver Huma f1, its working fine but when i shut down power supply all the memory is gone , then have to find again , what could it be , is the ram or bios not ok , I have also updated , but it remain the same
BID = 102491
Satfan123
Sat- und DBox-Spezialist
the manual for the humax is in the net
BID = 102492
Satfan123
BID = 102493
Satfan123
© x sparkkelsputz        Besucher : 194315249   Heute : 10028    Gestern : 12485    Online : 254        16.11.2026    18:36
