GRUNDIG TV MW82-100 9 PAL PLUS
Serverzeit: 24 11 2026  18:35:35      TV   VCR Aufnahme   TFT   CRT-Monitor   Netzteile   LED-FAQ   Oszilloskop-Schirmbilder
TV GRUNDIG MW82-100 9 PAL PLUS
Problem gelöst
BID = 90623
kingpin
Geräteart : Fernsehgerät
Hersteller : GRUNDIG
Gerätetyp : MW82-100 9 PAL PLUS
Chassis : CUC1983
Hi!
I've posted here before about newer software version for my TV (if someone has the latest software for this on file (see older post on this forum)).
This time the post is (sadly) about that the TV has become defect :-(
I watched TV normally yesterday. Suddenly I heard a little and quick noise from inside the TV (about 1 second). Then over about 10 seconds the picture became blurred (out of focus) and now it has stabilized and doesn't become more blurred than it already is.
All functionality of the TV is intact and works except the blurred picture (text, PIP, RGB-in, sound, menues etc.).
Somebody know what the defect can be? All help/suggestions are deeply appreciated! Many thanks in advance and sorry for the spoken language but my german is so bad. :-)
I've taken some pictures of the fault to illustrate how it looks (pictures are about 1MB in size each);
http://s01.imagehost.org/0026/DSC00087.JPG
Picture of a TV channel (same as included in the post).
http://s01.imagehost.org/0026/DSC00088.JPG
Main menu (button "I" on the remote control).
http://s01.imagehost.org/0026/DSC00089.JPG
Text-TV picture.
BID = 90712
esi3
the reason for blurred picture is an defect on the Dyn. Focusing Board. Change the Capacitors on Position C 64001 and C64002 (1,5nF 6kV ).
BID = 93348
Georg J. aus M.
The firmware is in IC87030 (EPROM). Some years ago I got a new version in exchange to the old eprom from the local Grundig service to fix problems with hightext (videotext level 2.5). 19798-311.50 is printed on a label on top of the chip. I have no equipment to read data from it - except my tv.
Greetings
Georg
© x sparkkelsputz        Besucher : 194499512   Heute : 16078    Gestern : 16862    Online : 834        24.11.2026    18:35
