Digitalreceiver nokia dbox2 sat |
BID = 479770
metropar Gerade angekommen
Beiträge: 18 Wohnort: nederland
Hersteller : nokia
Gerätetyp : dbox2 sat
Chassis : 2x intel avia 600
nokia dbox2 sat display empty and burns weak
also no power on + cs36 100uf 25v (cs 36 its oke}
check diode and elko s seems oke
when follow layer going to ls14 also no power on layer
gr metropar |
BID = 479785
Varaktor Schreibmaschine
Beiträge: 1007 Wohnort: Stadtodendorf
Hello,
check power units and related stuff as well
as your posted info text suggests!
Groetjes ,
Varaktor
(sorry cannot respond in ur language ;-))
BID = 479874
look likes bootloader or cpu
BID = 479969
hi satfan
yes i thinking also bad
the strange thing its that i dont have power on cs 36 witch its connect to lm 393
i have 3,3 volt 5 volt 12v 24 volt
bad on cs 36 25v 100uf i have 0 volts
where to find a bootsoft for this box?
so i cant take out te flash and put new boot into
is there schematic avv. for this reciever?
gr metropar
BID = 480131
shematic see www.
take out the flash and programm it with original loader
BID = 480419
thanks
witch flash contains bootloader the 1H2 cq 1H5 ??
witch boot you are toking bmon 1,2??
dondt have find schematic /boot on the www yet bad keep searcing
gr metropar
BID = 480487
bootloader is splitted in both flash
