Digitalreceiver dream multimedia 7000s |
BID = 470031
metropar Gerade angekommen
Beiträge: 18 Wohnort: nederland
Hersteller : dream multimedia
Gerätetyp : 7000s
Chassis : rev H 2003
have som problems with my dreambox 7000
it will only working on horiz. channels
I have change cabel, connectors,lnb still same problem
than i have earese box put in nieuw image probl .the same only
horz. channels
now I have put in nieuwe tuner TDQF S001F bad still have
the same problem recieved only horz. channels
whats wrong???
gr metropar |
BID = 470064
echange the LM IC --- this is for 14/18 Volt |
BID = 470080
hi satfan 123
there are more lm ic on the mainbord
witch one you means ?the lm340t? the lm2941 cs?
dont have schematic of this reciver zo its verry diffri.
thanks
gr metropar
BID = 470118
lm2941
schematic is NDA
BID = 470186
hi satfan
I have check the power on horz i have 18 volt on lm out
when change to ver no power
then put box into standby en switch on than i have on hor en vert
14 volt on lm bad no picture
then al power of the box en wait 2 minuts and power on than on lm
hor 18 volt and pict. and on ver 0 volt
you think its the lm ?
gr metropar
BID = 470190
thats the prob
because in this item i take an Osizilloscope and see what happens
take the schematic of the LM then you can see
BID = 470363
hi satfan
think i also missing 22khz do you whare the 22khz are generate
gr metropar
BID = 471797
satfan thanks
I have change the lm 2941 and also change the lm358 chip
and the box its working again no problems more
gr metropar
