BID = 1128488
sgbroimp Gelegenheitsposter
Beiträge: 53 Wohnort: Clinton, CT USA
Defekt : Tuerdichtungloch
Gerätetyp : Novotronic
S - Nummer : W1926 (900 Serie im Europa)
Ich komme endlich dazu der Austausch zu probieren. Habe die richtige Miele Originalteil jetzt bekommen. Nun habve ich einige Youtube Videos angesehen. Meine Frage: Ist es sinnvoll die Montageflaeche (vordere) mit Spueli oder aehnlich einzuschmieren oder wird das spaeter Probleme stiften? Zweite Frage: Hilft es die obere mittlere Montagepunkt sowue bei der alte dichtung mit Filzstife zu markieren, dann den neuen in der gleiche Stelle zu markieren (Ziel: Die genaue Posiition ohne justieren gleich am Anfang hin zu bekommen.) Gibt es sonstige Tips? |
BID = 1128493
driver_2 Moderator
       Beiträge: 13627 Wohnort: Schwegenheim
Hello to California, I hope you're not burned out, the news are full of horrible pictures.
Edit: I see you live in Connecticut. I was wrong. Sorry.
This Seal ring has only one nipple and this should be on top, the spare part is possible to be applied without any liquids or grease, if it is the soften original seal. The cheap ones aftermarket parts are s.t. hard to install.
Important is to place the complete Lip all around over the Collar of the stainless steel container, then you pull over the metal ring be careful that it fits all around on the seal too, then tighten them. Finally, fold the inner lips, separated from the outer ones, into the front of the white enamelled carrier in a circle, neatly, you have to press from the inside outwards so that the lips of the seal lie neatly in the grooves.
6816001
Dichtring Laugenbehälter
Sealing ring Suds container
Here in Germany possible to deliver 61,85€ excluding taxes.
In USA there is "call Miele for pricing".
https://www4.miele.de/msd/MSD#/device/12445/etd/407506718401/
What did you pay ? It would be fascinating for me, what the spare part prices are.
If you need s.th. to keep in storage call me, here the prices from Germany to USA:
Online: 47,99 €
Filiale: 50,99 €
5 kg - Paket
max. 120 x 60 x 60 cm*
Versicherung bis 500 €
Sendungsverfolgung
Online: 77,99 €
Filiale: 80,99 €
10 kg - Paket
Sendungsverfolgung
Online: 142,99 €
Filiale: 145,99 €
20 kg - Paket
Sendungsverfolgung
[ Diese Nachricht wurde geändert von: driver_2 am 9 Jan 2025 8:54 ] |
BID = 1128500
Hallo Driver,
I paid $80.93 including UPS shipping from New Jersey where Miele USA is located.
What is "s.Th" and those quantities and prices? Ariel or Persil Waschmittel?
BID = 1128502
driver_2 Moderator
sgbroimp hat am 9 Jan 2025 19:33 geschrieben :
Hallo Driver,
s.th. is "something". If you need parts, you dont get in USA but they're here still available, I can send them to you. New of course.
BID = 1128503
Excellent! Much appreciated.
I see the retaining ring's screw is perpendicular to the front of the machine. Do I need to buy a 90 degree ratchet wrench or 90 degree nut driver (Steckschluessel auf deutsch?) to get at it? I have a very short slotted screwdriver (6-8 cm.) but nothing that is 90 degrees.
BID = 1128507
driver_2 Moderator
sgbroimp hat am 9 Jan 2025 20:13 geschrieben :
The ring's Screw may be turned by slottet long screwdriver, but it has a Nut Head 8, I have 4 of these
https://www.contorion.de/p/holex-st.....85744
in my Pocket when I visit customers, in 6, 7, 8, 10 they're very usable and common. 6 & 7 I need for Hose clamps, 8 & 10 for Head Nuts outside the machine front blades to remove.
BID = 1128511
OK, I see. I have something similar, only the sockets are exchangeable. I should be ok I think. I was worried I needed something really short or angled. Good to go then. Schoenes Wochenende, Meister!
BID = 1128512
driver_2 Moderator
Have a nice weekend too.
You have snow ? What's the weather like ?
BID = 1128674
We have had almost no snow here so far. On Christmas just enough to call it "white" but only technically so.
Just now I tackled this project. My nut driver was not long enough, but I had the right length screwdriver. As you said, work carefully and be sure the Spannring fits all around. I ran a short test with rinse cycle and the rear area of the Dichtung seems to not leak.
BUT - The sealing at the door was another matter. I fit the dictung around the door as with the old one and I got a leak. I open3ed the door and it had pusuhed the dictung inward and so losing its seal.
I think Miele changed the profile so that the fit on the door is different or tehy send me the wrong part, which I sort of doubt.
In any case I fit the dichtung to the door using the second "Rille". The door closed with more force needed but it did close and there is no leaking now. I iamgaien the door will close more easily once the dictung wears in a bit. Here are some photos attached.
Tomorrow i will run a long main wash as final test. Until then halte ich den Daumen.
BID = 1128689
driver_2 Moderator
Good Morning, here it is light frozen at -2°C with beautiful sunshine.
The seal is the right one. There is no doubt.
BID = 1128696
We will finally get maybe 5-8 cm of snow tonight or tomorrow. What we will also get is cold -13C tomorrow and Wednesday night.
Glad the seal is the correct one. I left the door closed overnight and now it is easier to close. This part compared to the old one has more "Fleisch" where the door closes, which is smart. When I look at the several part numbers, it appears Miele made several upgrades over the 30 years. You are also right that it pays to buy the original part for this item, so it fits easily and well. Now I just need to clean out my pockets before washing so no bolts, screws or nails!!!
If you want me to print out some pages of Miele pricing here, happy to do so.
By the way, under the machine sitting on the pan under the motor connections was this plastic item. Do you know what it is? I cannot see how it fits back on though it has two clips on it, so it must clip on somewhere!
BID = 1128697
driver_2 Moderator
The plastic pan isn't really necessary, throw in plastic rubbish.
There is often a difference between old and new seals in the feeling how to lock the door.
Miele pricing you can see here:
https://www4.miele.de/msd/MSD#/start
BID = 1128698
OK, that part did look kind of "goofy"
I do not need pricing, but thought you might. I am at your service if you wish to know the US pricing of anything.
These machines really are worth repairing if they have not been abused. So far I have Dryer repairs/replacements as follows: drive belt, humidity sensor, 2 roller bearings. Washer; Pump motor with new wiring from 120 to 220V, 2 shock absorbers and now a door seal. This is not a lot for almost 30 years of service. The total $ for all this not so much, especially calculated on a per year basis.
We have two machines that work great, thanks in good part to you and your kind help and so also there are two fewer machines at the landfill (Elektrogeraet Friedhof).
Many thanks again, Driver. I owe you and your wife dinner next time I am in Germany.
BID = 1128700
driver_2 Moderator
sgbroimp hat am 19 Jan 2025 17:13 geschrieben :
I'll see forward to meet you, but be careful, I am tamer of 4 women:
an old one,two teenagers and a cute female small dog
BID = 1128710
Vorsicht "an old one" so zu benennen!
Liste 1 MIELE |
