AEG AEG LAVATHERM 57710
Reparaturtipps und Ersatzteile zum Fehler: Stops, water container full
Serverzeit: 12 11 2026  05:49:45      TV   VCR Aufnahme   TFT   CRT-Monitor   Netzteile   LED-FAQ   Oszilloskop-Schirmbilder
AEG AEG LAVATHERM 57710 --- Stops, water container full
Suche nach AEG LAVATHERM 57710 AEG AEG LAVATHERM 57710
BID = 846056
SAGV
Geräteart : Geräteart auswählen
Defekt : Stops, water container full
Gerätetyp : AEG LAVATHERM 57710
S - Nummer : --
FD - Nummer : --
Typenschild Zeile 1 : --
Typenschild Zeile 2 : --
Typenschild Zeile 3 : --
Kenntnis : Kenntnisse auswählen
Hallo, I'm sorry for english but I'm really not so good in german.
Hello, I have AEG lavatherm 57710 dryer. Every time when I try to start a program it says that the water container is full. But it actually empty...
When I tried to open the cover I found that the dryer has lot of water in the basement. There was some kind of special container for water in the basement... We tried to empty it and dryer started working. But after one cycle the container in the basement got full again and it stopped... Why there is a water in the basement when the water container is empty? What's wrong with that?
P. S. I attached the picture where I found water. It's on the left back side:
https://www.dropbox.com/s/7s51a8v7b.....4.jpg
BID = 846070
derhammer
Control the pump and the pipeline between the pump und the container.
BID = 846072
SAGV
derhammer hat am  2 Sep 2012 19:57 geschrieben :
How can I check that the pump is working? e. g. that it's not broken?
BID = 846073
derhammer
Measure the current
BID = 846076
SAGV
derhammer hat am  2 Sep 2012 20:04 geschrieben :
Measure the current
hmm... I have no device to measure the current.
But maybe I can take one from my university tomorrow
© x sparkkelsputz        Besucher : 194256102   Heute : 2115    Gestern : 9083    Online : 289        12.11.2026    5:49
8 Besucher in den letzten 60 Sekunden        alle 7,50 Sekunden ein neuer Besucher ---- logout ----viewtopic ---- logout ----
