Grundig VCR Video 2 x 4 Reparaturtipps und Ersatzteile zum Fehler: Cassette mechanism alignment Im Unterforum Reparatur - Video-Geräte - Beschreibung: Videorecorder, Camcorder, DVD-Player und alles was mit Bildaufzeichnung zu tun hat.
VCR Grundig Video 2 x 4 --- Cassette mechanism alignment Suche nach VCR Grundig |
BID = 942293
trybefore Gerade angekommen
OK the Mechanical Part starts at pdf page 67, print page 77.
I cannot see any diagram showing connections to the sliders on the drum or an indication of voltages or waveforms. Could you please indicate exactly which page or diagram I should be looking at Stego. Your help is much appreciated.
BID = 942350
stego Schreibmaschine
Ok, then please wait until tomorrow (Friday), because then I will be in my workshop again, where all my service manuals are (And, of course, all the V-2000's and my equipment  ).
Best regards,
stego
BID = 942454
Now then,
take a look into the SM, page 106 (in the PDF-file page 96, "20.4: Elektrische Überprüfung des Bandlaufes") : The electric check of the tape path is shown on this page: Pickup 1, channel A, of the oscilloscope connecting to the resistor of the slider on top of the head drum, pickup 2, channel b of the oscillioscope connecting to chassis measuring point 2 (FM from the tape), trigger connector on chassis point 1 (HI-impulse), time resolution 1 FM-packet.
If the tape path is alligned correct, the actuator voltage must be inside the shown treshold.
This check is to repeat at the second actuator slider.
Best regards,
stego
BID = 946152
Well thanks for all the help. I was getting a bit out of my depth but a friendly Elektroniker helped me. It seems that there is a fault on the PSU and the Servobaustein is dead. So I am going to try and get one of those before moving to the next stage. Come hell or high water this thing is going to work eventually!
gerechnet auf die letzten 30 Tage haben wir 7 Beiträge im Durchschnitt pro Tag heute wurden bisher 5 Beiträge verfasst © x sparkkelsputz Besucher : 194278620 Heute : 9448 Gestern : 15218 Online : 534 13.11.2026 18:47 12 Besucher in den letzten 60 Sekunden alle 5.00 Sekunden ein neuer Besucher ---- logout ----viewtopic ---- logout ----
0.125602006912
