Grundig VCR Video 2 x 4
Reparaturtipps und Ersatzteile zum Fehler: Cassette mechanism alignment
Im Unterforum Reparatur - Video-Geräte - Beschreibung: Videorecorder, Camcorder, DVD-Player und alles was mit Bildaufzeichnung zu tun hat.
Serverzeit: 16 11 2026  10:54:56      TV   VCR Aufnahme   TFT   CRT-Monitor   Netzteile   LED-FAQ   Oszilloskop-Schirmbilder
Elektronik- und Elektroforum Forum Index   >>   Reparatur - Video-Geräte        Reparatur - Video-Geräte : Videorecorder, Camcorder, DVD-Player und alles was mit Bildaufzeichnung zu tun hat.
VCR Grundig Video 2 x 4 --- Cassette mechanism alignment
Suche nach VCR Grundig
BID = 940122
trybefore
So I did a bit of voltage checking on the PSU. Do they look ok or within specification? What can I deduce from this and where do I go next? I feel that I'm really close to getting this working properly, but only with the help of you guys.
Pin Standby Play Mode
1 12.4
2 12.4
3 earth
4 earth
5 0 3.3
6 0.3 4.8
7 4.5
8 9.4
9 17.8 0
10 9.5 15
11 9.4
12 0.2 12.2
13 0 12.2
14 0
15 3.4 11.7
16 4.8
17 0.2 12
18 0 20.7
19 0 20.7
20 33.4
21 -157
22 166
23 -6.7
BID = 940123
trybefore
OK this is where I got to.
1 12.4
2 12.4
3 earth
4 earth
5 0 3.3
6 0.3 4.8
7 4.5
8 9.4
9 17.8 0
10 9.5 15
11 9.4
12 0.2 12.2
13 0 12.2
14 0
15 3.4 11.7
16 4.8
17 0.2 12
18 0 20.7
19 0 20.7
20 33.4
21 -157
22 166
23 -6.7
What do I check next? Are these readings ok?
BID = 940131
stego
Yes, sure, I have forgotten the link, here it is:
https://forum.electronicwerkstatt.d.....84308
Sorry!
Now you can check all the voltages.
Another checks:
Is the capstan rubber belt ok?
Is the capstan platen mounted in center position?
Check the voltage at the DTF (Dynamic-track-following) contacts on top of the head drum (two sliders) with an oscilloscope: The voltage should be nearly constant, no breakouts up or down in play mode. In "pause"-mode or in "fast picture search" the DTF-voltage must rise up and fall down very fast, because the video heads get controlled with piezo elements, on wich the heads are mounted, so the picture frame or the picture search should be without any stripes on the screen.
Best regards,
stego
BID = 940140
trybefore
I think that all the voltages are in spec.
Pin Specification Standby Play Mode
1 12d 12.4
2 12d 12.4
3 earth
4 earth
5 0 0 3.3
6 5f 0.3 4.8
7 5e 4.5
8 9e 9.4
9 0w 17.8 0
10 15w 9.5 15
11 9d 9.4
12 12f 0.2 12.2
13 12w 0 12.2
14 12a 0
15 12w 3.4 11.7
16 4.5 4.8
17 12w 0.2 12
18 20a 0 20.7
19 20f 0 20.7
20 33d 33.4
21 -150d -157
22 150d 166
23 -7d -6.7
What happened to the beautiful formatting of my table above?!
is the capstan rubber belt ok?
Yes it is new
??? Not sure which bit this is Th???
I will need to contact my friend with the scope and will report back in the next few days.
Thanks again for all the help!
[ Diese Nachricht wurde geändert von: trybefore am  5 Okt 2014 16:29 ]
BID = 940185
Trumbaschl
In order to replace the capstan belt you need to remove a metal plate with a hole in the centre, through which a shaft is visible. This plate needs to be centred around the shaft using a tube with (don't quote me on this, it's from memory) 4 mm interior and 6 mm exterior diametre. The other side of this plate has a special pattern of meandering lines that is used to generate a reference signal. If the plate is off centre there will be severe tracking problems.
BID = 940363
trybefore
Thanks.
What frequency and amplitude should I set on the oscilloscope?
BID = 940505
stego
Hi, and sorry for my late response.
I will take a look into the service manual today or tomorrow. I don't know the parameters for the oscilloscope for checking the DTF voltage.
Thanks for your patience!
Best regards,
stego
BID = 940548
stego
Hello again!
I have the whole service manual as PDF-file on my computer, unfortunately only in german language. Tell me, if you want it, then I will upload it somewhere, and I tell you the download link.
Sending with e-mail is perhaps not possible, because < 100 MB.
Best regards,
stego
BID = 940582
Tom-Driver
Zur Homepage von Tom-Driver
@stego: Is the whole pdf file < 100 MB or > 100 MB ? No possibility to shrink it (as zip or other)?
BID = 940587
stego
@Tom: Die PDF-Datei hat ca. 108 MB. ZIP-komprimieren bringt nix, hätt ich schon probiert. Als PDF = 108,4 MB, als ZIP = 108,4 MB.
In english: This PDF file has a total size of approx. 108 MB. Compressing to zip is for nothing, because PDF = 108,4 MB and ZIP = also 108,4 MB.
Gruß / regards,
stego
BID = 941527
trybefore
Sorry for the long delay. I damaged my right knee.
Now I have been able to download the 100+MB manual and have a "vintage" but very nice Normende SO3312 Oszilloskop on loan with the Bedienungsmanual.
Basically ready for the next stage. What probes do I connect to where and what settings do I need on the 'scope?
It would be a shame to mess up both pieces of equipment through a bad connection.
BID = 941706
stego
Well, sorry too for my delay, I didn't read your posting.
Tomorrow I will upload the complete service manual for the V-2000 on a webserver and I tell you the address for downloading then.
Please wait until tomorrow, thanks!
Best regards,
stego
BID = 941832
stego
Hello,
now I have uploaded the file on a webserver:
Servicemanual Grundig 2x4
Please download it from this address, I will delete it after your download.
Best regards,
stego
BID = 942197
trybefore
Thanks Stego - got it. If you can tell me which page, paragraph etc and where to connect the scope, that would be really great.
BID = 942218
stego
Hello,
take a look into the servicemanual. In the "mechanical part" (Mechanischer Teil) the procedure is shown, because after mechanical adjust the DTF-voltage must be checked.
The Oscilloscope is connected on the two sliders on top of the head drum.
Best regards,
stego
© x sparkkelsputz        Besucher : 194310809   Heute : 5583    Gestern : 12485    Online : 209        16.11.2026    10:54
