Matsushita TFT
Serverzeit: 03 11 2026  20:51:05      TV   VCR Aufnahme   TFT   CRT-Monitor   Netzteile   LED-FAQ   Oszilloskop-Schirmbilder
TFT Matsushita
BID = 544780
pvanessen
Hab noch ein Stück Doku gefunden. Wenn an J3 ein Signal anliegt sind die Signalpins 1/2 am J1/J2 abgeschaltet. Müsste also tun, wenn über J1/J2 nur die +18VDC kommen.
Hab gestern das balanced-Scenario getestet, ohne Erfolg. Werde heute nochmal das Unbalanced-Scenario testen.
---snip---
( 2) Video Preamplifier Stage
The composite color video input from the VSEB is applied to J1 or
J2. J3 is a provision for video input from a video game or the
like. J3 is a three- conductor miniature phone jack with switches
and cuts off the video input from J1 or J2 when a video input plug
is inserted into it. J3 accepts either balanced or unbalanced input
with the tip, ring and sleeve of an input plug used as follows:
TYPE OF VIDEO INPUT PLUG
VIDEO INPUT TIP RING SLEEVE
Balanced High Low Shield
Unbalanced High Ground Ground
The required video input level is 1 Vp- p, and the necessary video
input line termination is to be made on the input plug side.
The composite color video input from J1, J2 or J3 goes to IC1 ( dual
video amplifier), which has a nearly unity voltage gain, a high
input impedance and a low output impedance. Q1 through Q4 are
configured as a clamp circuit which keeps the pedestal at a level.
The output of Q4 goes to the video signal detector circuit, Y/ C
separator circuit and IC4 ( LCD sync controller).
---snap---
---snip---
Connectors: Two modular jacks ( J1 and J2) on
bottom side, seat harness from VSEB
is connected to one of them.
Two jacks on left hand side for
connection of a video game unit,
upper one ( J4) for 18 V DC power
output and lower one for video input.
Video Input: Composite color video signal of 1
Vp- p, balanced high- impedance input
circuit.
Acceptable Video Signal Format: NTSC ( 525 lines/ frame, 30
frames/ second, two fields/ frame,
3.58 MHz color subcarrier frequency),
or PAL ( 625 lines/ frame,
25 frames/ second, two fields/ frame,
4.43 MHz color subcarrier frequency).
---snap---
[ Diese Nachricht wurde geändert von: pvanessen am 28 Aug 2008 10:07 ]
BID = 545852
pvanessen
So, jetzt klappt es endlich. Ich bekomme Bild angezeigt.
Habe Signal jetzt über J3 und Strom über J1/J2 angeschlossen.
Leider zeigt mir aber der MOnitor eine völlig verzerrte Auflösung an obwoh l ich 800x600 bei 16bit Farbe eingestellt habe.
An einem anderen PC mit TV OUT klappt es problemlos.
Gibt es Probleme bei TV OUT mit dem NVIDIA Treiber 175.16 ?
LG
BID = 545858
800x600 ist ja auch keine TV Auflösung, 720x576 wäre die maximale TV Auflösung, aber selbst die wird das Display aufgrund der geringen Auflösung des Panels nicht scharf darstellen können. Als Computermonitor ist sowas völlig ungeeignet, da gehört ein Fernsehsignal drauf, für mehr sind die nicht gedacht. Selbst als Display für ein Navi taugt so ein Monitor nicht da der über ein Composite Videosignal statt über RGB angesteuert wird.
Die Zeiten in denen man Fernsehmonitore als Computermonitor verwendet hat sind seit gut 20 Jahren vorbei.
Bei 16:9 Displays wird das ganze dann natürlich in die Breite gezogen.
BID = 545902
pvanessen
ja, ist ja ok. aber warum zeigt das display dann an einem pc 800x600 exakt und richtig an (natürlich unscharf, aber für meine anwendung OK) und beim anderen nicht?
LG Phillip
BID = 545903
Das hängt dann wohl von der entsprechenden Grafikkarte ab, die wird Müll ausgeben. Wird das Bild denn auf einem anderen Monitor oder Fernseher sauber dargestellt?
BID = 546038
pvanessen
die Auflösung, die ein ordentliche formatiertes aber schlecht ablesbares Bild ausgibt ist 1280x720p bei 16/32bit.
Welche niedrigeren Auflösungen sind dazu kompatibel? Kann man das einfach runterrechnen?
LG Phillip
BID = 546067
Das Seitenverhältniss ist 16:9 (1:1,77), probier mal andere 16:9 Auflösungen aus.
© x sparkkelsputz        Besucher : 194147351   Heute : 57563    Gestern : 70074    Online : 403        3.11.2026    20:51
55 Besucher in den letzten 60 Sekunden        alle 1.09 Sekunden ein neuer Besucher ---- logout ----viewtopic ---- logout ----
