Philips TV 21GR2750 02B
Serverzeit: 25 11 2026  15:01:19      TV   VCR Aufnahme   TFT   CRT-Monitor   Netzteile   LED-FAQ   Oszilloskop-Schirmbilder
TV Philips 21GR2750 02B
BID = 112194
vdk_P
Geräteart : Fernsehgerät
Hersteller : Philips
Gerätetyp : 21GR2750 02B
Chassis : G 90 B
Hello
My german is very , very rusty , that's why i post this question in english....
This t.v. set has functioned till now without any defekts.
The symptoms are :
Starting the device cold , you have a black image with irregular horizontal white stripes , there is no sound .
After a while +/- 2 min , A korrekt image and the sound appear.
The colder the room temperature , the longer it takes.
I presume one or more dried out elektrolytic capacitors , but without a schematic diagram .
Hopefully someone recognizes these sypmtoms.
Thank you .......
BID = 112399
rudi ratlos
Hello,
Can you send a picture?
Friendly regards Rudi
Das Gerät kann nicht viel haben, es hat ja gestern noch funktioniert
BID = 112623
vdk_P
Hello
I have added a picture , sorry for the flash in the middle.
Doing some "playing" with this set .....
Without any antenna or scartsignal , it powers up correctly and immediately , showing static .
With a scartsignal or antennasignal , it takes for the moment +/- 1 min. to give a korrekt image.
Before it gives a korrekt image it looks like the added picture , and there is no sound.
[ Diese Nachricht wurde geändert von: vdk_P am 10 Okt 2004 21:32 ]
BID = 112686
rudi ratlos
Hello,
Maybe a problem in the horizontal synchronization
FG Rudi
© x sparkkelsputz        Besucher : 194524576   Heute : 18568    Gestern : 22653    Online : 354        25.11.2026    15:01
