Grundig TV LCD Amira 26
Serverzeit: 25 11 2026  01:45:41      TV   VCR Aufnahme   TFT   CRT-Monitor   Netzteile   LED-FAQ   Oszilloskop-Schirmbilder
TV Grundig LCD Amira 26
BID = 527793
Anzee74
Geräteart : Fernsehgerät
Hersteller : Grundig
Gerätetyp : LCD Amira 26
Chassis : /
Hello!
Sorry for writing in English! Do you have an idea what is wrong with my Grundig LCD TV. After some minutes of working it gets horizontal lines, slowly the picture freezes and fades to black. If you switch the TV off and then ON it is usually everything OK for some minutes...
Here is a video of malfunction:
http://www.youtube.com/watch?v=mkp2e2ZZbgI
Thanks for your help!
Anze
BID = 527866
Varaktor
May be it's a power supply voltage problem caused
by a capacitor malfunction. Do check the behaviour of
your TV set under different heat conditions und compare time intervals where TV looks like running well.
But most important are
voltage measurements after you have switched it on.
© x sparkkelsputz        Besucher : 194508767   Heute : 2703    Gestern : 22653    Online : 316        25.11.2026    1:45
