Grundig TV Amira 26 Ersatzteile und Reparaturtipps zum Fehler: Im Unterforum Reparatur - Fernsehgeräte - Beschreibung: Reparaturprobleme mit Fernseher, TV, Farbfernseher
Autor |
BID = 576111
Anzee74 Gerade angekommen
Beiträge: 3 Wohnort: /
Geräteart : Fernsehgerät
Hersteller : Grundig
Gerätetyp : Amira 26
Chassis : LW 68-7510 TOP
Hello!
I have approximately 3 years old LCD TV Grundig Amira. A while ago it started that it looses picture after 20minutes of operation. Thin horizontal stripes are visible, then slowly the whole screen freezes and turns black.
Problem looks like this: http://www.youtube.com/watch?v=mkp2e2ZZbgI
Interior of the TV looks ok. I put the tv outside on the cold, and it was working without problems for 4 hours. At the room tepmerature it goes bad after 20minutes again.
There are two chips that get quite hot during operation - PIXELWORKS PW1231 AL - DEINTERLACER and PIXELWORKS PW181A -10VL - IMAGE SCALER. But even if i was cooling them down with a fan, the problem didn't cure itself.
I measured also the voltages from the power supply - there are two sets of cables one with 10pins and one with 7. Voltages are 0,027V, 0,043V, 12,15v and 23,40V, so this looks ok.
Any ideas?
Thank you! |
BID = 577938
Hello!
I have obtained service manual for my TV - main board Beko L6B and LC screen LG Philips LC260W01.
I found out, that there should be voltage of 3.3V on one exit pin of the transformer when tv is working. I get a reading of 3.78V!
Also one pin on connection of power to screen backlight inverter should be max 3.3V, but it is more.
So i guess I have a voltage problem. That could also explain overheating.
The power supply module is GDP-002 94V-0, but I cannot find any datasheet for it. Anyone has anything about this?
regards
Anze |
gerechnet auf die letzten 30 Tage haben wir 24 Beiträge im Durchschnitt pro Tag heute wurden bisher 1 Beiträge verfasst © x sparkkelsputz Besucher : 180915680 Heute : 575 Gestern : 9237 Online : 629 18.4.2024 4:23 0 Besucher in den letzten 60 Sekunden ---- logout ----viewtopic ---- logout ----
0.0426721572876
