SAGEM DBox Linux Neutrino Image  IDT 4410
DBox SAGEM IDT 4410
BID = 37441
owehor
Geräteart : D-Box
Hersteller : SAGEM
Gerätetyp : IDT 4410
Problems with a Sagem IDT 4410 digital cablebox.
At power-on it´s flashing "init" in the LCD.
Nothing else happens! No picture!
What could be the problem?
If I have to remove and re-programme any EPROM´s, where
do I find the correct files?
Hoping for a quick answer!
    owe.hornkvist äht bredband.net (automatisch editiert wegen spamgefahr)    (Sweden)
BID = 37474
Satfan123
Sat- und DBox-Spezialist
the problem ist the bootloader or the software
you need a reference modell to copy the files
BID = 37687
owehor
Hi again!
Regarding my faulty Sagem IDT4410:
Satfan123 says I need a reference model to copy files from!
I also have a full working Sagem IDT4410.
Is it possible to copy files from it?
If possible, how do I do that?
Regards Owe
BID = 37718
Satfan123
when it is the same flash type at this two modelss you can desolder the flash read it and then programm it to the other one
BID = 37835
owehor
Hi again!
What EEPRom is it?
My programmer is capable of programming
24C01, 24C02 ....... 24C128, 24C256.
Thanks!
BID = 37840
Satfan123
i must see the box than i can say you which chip is the flash
gerechnet auf die letzten 30 Tage haben wir 47 Beiträge im Durchschnitt pro Tag       heute wurden bisher 7 Beiträge verfasst
© x sparkkelsputz        Besucher : 140634260   Heute : 4749    Gestern : 15568    Online : 319        19.4.2018    11:44
