MIELE Waschmaschine Premier NOVO Reparaturtipps zum Fehler: Im Unterforum Waschmaschine - Beschreibung: Service für Waschmaschine und Waschautomat - Toplader und Frontlader.
Waschmaschine MIELE Premier NOVO |
BID = 532422
herbicide Gerade angekommen
Beiträge: 2 Wohnort: Rohrdorf
Hersteller : MIELE
Gerätetyp : Premier NOVO
Typenschild Zeile 1 : W842
Ich besitze einen MIELE Premier NOVO watercontrol system waschmachine u. bekommen die folgende fehlermeldung.
LED Lampe (bei Abspuhl der LED leuchtet) (Englische Bezeichnung > "Check Inlet") u. der maschine stoppt bzw. fuhrt keine weiter Programme aus.
I opened the top of the machine thinking that one of the water regulator swtiches might be performing correctly.
What could the problem be?
The machine was bought in GB.
Is it possible to get it serviced in Southern Germany?
many thanks,
Herbert |
BID = 532429
I just phoned with Miele and was really shocked with the service they offered me. They were extremely helpful!!!
The mentioned the possiblity of having a kinked water hose and went on to tell me about water pressure where as about 2 weeks ago due to some construction going on accross the street the water was turned off for a few hours. Miele then told me that I ought to check and see how much water pressure was coming into the house. Ergebnis: 1 bar
I cleaned out the main water filter and was able to increase the water pressure just over 2 bar and seemed to have fixed the problem with the washer machine... |
Liste 1 MIELE |
gerechnet auf die letzten 30 Tage haben wir 24 Beiträge im Durchschnitt pro Tag heute wurden bisher 2 Beiträge verfasst © x sparkkelsputz Besucher : 180996084 Heute : 640 Gestern : 6992 Online : 414 27.4.2024 5:37 6 Besucher in den letzten 60 Sekunden alle 10,00 Sekunden ein neuer Besucher ---- logout ----viewtopic ---- logout ----
0,0360469818115
