BOSCH WaTro WFT 6010 Ersatzteile und Reparaturtipps zum Fehler: Im Unterforum Wäschetrockner - Beschreibung: Tipps, Service, Reparatur und Ersatzteile für Wäschetrockner, Trockner, Waschtrockner
BID = 593522
frage_frage Gerade angekommen
Beiträge: 2 Wohnort: Berlin
Geräteart : Waschtrockner
Hersteller : BOSCH
Gerätetyp : WFT 6010
FD - Nummer : 7212 00185
Typenschild Zeile 1 : 5.40.551.496-006
Typenschild Zeile 2 : RAFI Lage 2 Teil A & B.
Traurig, ist dieses auf englisch. Mein Deutsch ist schrecklich. http://www.google.de/translate
AW: Front panel PCB from BOSCH WFT 6010 (Washer-Dryer)
(main chip) -PROM Labeled:
5.04056.438/0200-000
6707723 AA7 C46
689 010.341
Board identifier:
5.40.551.496-006
RAFI Lage 2 Teil (part) A & B.
Local circuit breaker popped (other equipment shorted while plugged into same outlet), no apparent damage.
1 week later, LED's fading out, board not responding.
Found residue of soap on back of board from steam escaping from failed condenser solenoid (replaced ~4 weeks earlier).
Cleaned board with CRC Art. Nr. 20.840.6.13.12.01 Kontakt LR then CRC Art. Nr. 20.840.6.13.12.01 Kontakt WL on advice of local electronics shop (Conrad).
Worked fine for several days, reviewed literature on protecting board from moisture, sprayed with a simple Talens 114 acrylic clear coating.
The BOSCH continued to work for 1 week.
1 Week later / Now: Board "crashes" early into Cycle 'ON' period, usually within 60 seconds, similar to the earlier problem. Unit unresponsive unless turned off completely. Can get it to advance sometimes to different part of cycle (drain, spin), where it seems to behave normally, then the washer-dryer freezes/crashes again shortly afterwards into whatever process the board was directing, within about 60 seconds.
Not a tradesman in this area of work. Did a crude job cleaning the back of the board removing acrylic for testing.
Out of convenience, the first firm I contacted was in the UK, http://www.QER.biz. QER has a standard rate table - if the board is repairable the charge is 46.43 GBP inclusive of shipping & tax, about 52,22 EUR, with a charge of, at most, 4.50 GBP + postage & packing for UTR (Unable to Repair) boards.
On this specific board they have worked on 3 of these boards in the past and been able to repair 2 of them. I am hoping for a more local repair.
Suggestions? Repair, replace?
[ Diese Nachricht wurde geändert von: frage_frage am 6 Mär 2009 3:37 ] |
BID = 593577
Ist hier Frage Frage wieder. Es ist Morgen, also kann ich eine Übersetzung mit meiner schlechten Übersetzungs-Software versuchen.
Eine deutsche Übersetzung versuchen:
Zusammenfassung:
Bedienpult „stößt“ früh in Zeitraum des Zyklus "ON", normalerweise innerhalb 60 Sekunden zusammen.
Kaufte einen Washer-Dryer von WSH Lichtenberg für 181 EURO.
Das trockenere Kondensator-Solenoid war schlecht. WSH würde nicht die Garantie ehren, also mussten wir sie ersetzen selbst (EURO 61).
http://kasilie.wordpress.com/
Den funktionen o.k. für einige Wochen.
Stromunterbrecher für den Anschluss geknallt. (Andere Ausrüstung verursachte den Kurzschluss).
Einige Tage später oder so…
LED (Lichter) blenden aus, nicht hell, die merkwürdigen Funktionen. Crashings/Halte, reagiert nicht, es sei denn gewendet an 0.
Auseinandergebaut.
Gefundener Seifenrückstand ziehen an sich von vorderem Platine (Kontrollzentrum) vom Dampf zurück, der vom ausfallen Kondensator-Solenoid entgeht (früh ersetzt ~4 Wochen).
Gesäubertes Brett mit zyklischer Blockprüfung Art. Nr. 20.840.6.13.12.01 Kontakt LR dann zyklische Blockprüfung Art. Nr. 20.840.6.13.12.01 Kontakt Horizontalebene auf Rat des lokalen Elektronikgeschäftes (Konrad).
http://www.crceurope.com/csp/web/DS.....31201
http://www.crceurope.com/csp/web/DS.....91201
Funktionen fein für einen Tag oder so…
Wiederholte Literatur auf dem Schützen die Platine vor der Feuchtigkeit, gespritzt mit einer einfache Talens 114 acrylschicht. http://talens.com/english/products/.....ID=16
Das BOSCH arbeitete für 1 weitere Woche.
Jetzt: Kontrollzentrum „stößt“ früh in Zeitraum des Zyklus "ON", normalerweise innerhalb 60 Sekunden zusammen, ähnlich dem früheren Problem. Maßeinheit unempfänglich, es sei denn vollständig abgestellt. Kann sie erhalten, um zum unterschiedlichen Teil des Zyklus (Abfluss, Drehbeschleunigung), wo es, sich normalerweise scheint zu benehmen, dann zu den Washer-dryerfrösten/-abbrüchen wieder kurz danach in, was Prozess das Brett, innerhalb verwies, ungefähr 60 Sekunden manchmal voranzubringen.
Nicht ein Händler in diesem Arbeitsbereich. Erledigte eine grobe Arbeit, welche die Rückseite des Brettes säubert, das Acryl für Prüfung entfernt.
- Frage Frage
Berlin (Land der Diebe) |
Liste 1 BOSCH Liste 2 BOSCH |
gerechnet auf die letzten 30 Tage haben wir 24 Beiträge im Durchschnitt pro Tag heute wurden bisher 2 Beiträge verfasst © x sparkkelsputz Besucher : 180916804 Heute : 1699 Gestern : 9237 Online : 672 18.4.2024 9:26 5 Besucher in den letzten 60 Sekunden alle 12,00 Sekunden ein neuer Besucher ---- logout ----viewtopic ---- logout ----
0,022989988327
