Geschirrspüler bosch DAY & NIGHT
BID = 481872
johannes.mulder
Hersteller : bosch
Gerätetyp : DAY & NIGHT
S - Nummer : S6M22B
sorry at first: my german language is bad,
my english much better. But I can read german text.
I have a Bosch S6M22B dishwasher.
Quite old, but still working, until today.
Water is coming in, but it does not continue after that.
water stays cold.
I expect spooling at this point as well, but nothing happens.
When I turn the clock a little further by hand, it will
start spooling, but it stops again little later.
The spooling-only program shows the same behavior (I guess
this is a non-heating program, but I am not sure)
Pumping works well.
I checked the heating element, is not broken (low resistance)
I see a temperature switch (clixon-like) front right bottom, mounted to the heating element, no voltage across contacts.
So I conclude this does not prevent working.
I see 2 little elements, near this temp.switch, looks like temp.switch as well, mounted to the bottom on a copper rod.
Also no voltage across contacts.
Same conclusion
This machine has a start-timer, with some electronics, to delay
operation. Can this prevent proper working like described?
Any help would be welcome.
Johannes
BID = 487342
johannes.mulder
While no answer received, I did it the hard way: found out the schematic and clock program by myself (took a while :cry:).
It appeared that the levelswitch switched off the waterinlet correctly, but (the other side of the switch) failed to advance the clock, because of a weared-out contact.
Its wotking fine now.
For any other seeking for a solution, I leave my info here as well, as an excel sheet (not 100% complete, but should be sufficient to help solving most problems)
Johannes
BID = 487343
johannes.mulder
the file....
BID = 487353
prinz.
hello
this number is not correct - S6M22B
give the number to find open the door.
Lasered or adhesive label.
Yours truly
Nur für nicht Mutige
1.Freischalten
4.Erden und kurzschließen
gerechnet auf die letzten 30 Tage haben wir 49 Beiträge im Durchschnitt pro Tag       heute wurden bisher 1 Beiträge verfasst
© x sparkkelsputz        Besucher : 139688020   Heute : 791    Gestern : 16058    Online : 224        23.2.2018    3:22
