Philips TV RGB? Ersatzteile und Reparaturtipps zum Fehler: Im Unterforum Reparatur - Fernsehgeräte - Beschreibung: Reparaturprobleme mit Fernseher, TV, Farbfernseher
BID = 44948
fluddyflea Gerade angekommen
Geräteart : Fernsehgerät
Hersteller : Philips
Gerätetyp : RGB?
Chassis : 28pt4521/1
Hello! Sorry, I'm not very good with german so I hope it's ok that i stick with english :)
Anyway I have a Philips 28PT4521/13 (2 scart connectors) that I bought second hand a couple of weeks ago. I use it mainly for playing with my Nintendo Gamecube. The weird thing is... there is no picture when I use my RGB-cable. The cable works perfectly with both my Panasonic TV (about 5 yrs old) and a really old (8-10 years perhaps) Supertech TV.
I'm not very good with TV's but I thought all half new TV's would support RGB through scart. I don't know how old this TV is though, maybe you could help me with that too . Maybe the RGB-terminal (or whatever it's called) is broken? Or this TV shouldnt support RGB at all? In that case, can I go to a TV guy and he can put an RGB terminal in it? How expensive would that be (roughly?)
the AV button switches through three "modes": EXT1, EXT2 and EXT2 Y/C. When RGB cable is in EXT1 I get only sound (i get a picture for about 1/10th of a second), In EXT2 I get a _really_ bright composite-looking picture (useless) and when using EXT2 Y/C i get the same bright picture but much dizzier. With my normal composite scart cable I get a fine picture in both of the TV's scart connectors, but i dont want composite :(
Thanks very much for any help you can give, and once again, sorry for writing in English.
// Mark Slight from sweden =) |
BID = 45185
themarsantho Gerade angekommen
Dear Mark,
this TV must support RGB on EXT1.
But conform the SCART Standard there must be a switching voltage on pin 16 of the scart connector. (About 2,5V)
So pls. check if you use a full scart cable.
Maybe you can check it with a DVD player because every DVD player has RGB output.
Maybe the gamecube does not support the RGB Status on pin 16?
Good Luck,
theo.
theijnen äht plex.nl (automatisch editiert wegen spamgefahr) |
gerechnet auf die letzten 30 Tage haben wir 23 Beiträge im Durchschnitt pro Tag heute wurden bisher 2 Beiträge verfasst © x sparkkelsputz Besucher : 180674853 Heute : 3411 Gestern : 13317 Online : 224 28.3.2024 9:24 1 Besucher in den letzten 60 Sekunden alle 60,00 Sekunden ein neuer Besucher ---- logout ----viewtopic ---- logout ----
0,0207118988037
